Connecting Batteries Together. (1 Viewer)
indytravels
5
About to buy one
Caravan since 1985
I am fitting 3x 100w solar panels and connecting them to the batteries via a Votronic MTTP 350 Dual controller.
The two leisure batteries seem to be connected together (in parallel) at the built in battery charger, would I be better to also connect the two batteries (in parallel) with direct cables?
The cables going into the charger look quite thin, when I connect a separate battery charger to one battery and take a reading from the other it reads 0.10v lower than the one with the charger connected.
My plan is to connect solar to one battery and a b2b charger to the other battery. Any advise greatly appreciated.
Mar 23, 2012
9,524
31,938
sleights
c class
Not an expert but I would have thought the max charging current to be a lot lower than the max output from the battery if say an inverter was being used so should be fine. Of course it could be said the thicker the better to avoid any loss
Oct 2, 2008
4,464
7,928
Salopia
Duro 6x6 Overlander
since 1968
If bats in parallel , then it is usual to put neg to one battery and pos to other battery for any input or take off there are several threads on here about connection of batteries in series and parallel and cable sizes and lengths . HTSH
http://www.solarseller.com/battery_bank_wiring_diagram.htm
Lenny HB
53,288
149,421
On the coast in West Sussex
Hymer B678 DL
The batteries should connected together next to each other not at the charger. Use a decent size cable at least 16 mm sq. While at it worth replacing the cables to the charger as well. If it's a Brit van they are famous for using well under size cables.
I
indytravels
5
About to buy one
Caravan since 1985
Thank you everyone for your help and advise. I will be connecting the two batteries together using 16mm cables, and connect the solar panels/b2b across the two batteries.
Apr 27, 2016
6,853
7,951
Manchester
A class Hymer
Since the 80s
When connecting batteries in parallel banks, it's best to use thick wire to minimise voltage losses. But more important is to arrange the connections so the voltage losses are equal. Otherwise one battery will always be charged slightly less than the others, which is detrimental long-term.
If there's just one charger source, then having equal lengths all the way from battery to charger is one way of doing this. It doesn't work so well with multiple charging sources.
The arrangement in @tacr2man's post is a popular alternative for two batteries. For more than one charge source (B2B, Solar) connect them all to the same terminals as the charger, not to different ones.
Abacist
3,709
10,492
Devon
N & B Arto 88F Tag
since 2013
Personally I would connect the two batteries together with large cables to form one big battery and then connect the solar controller to the batteries and also the B2B charger. Then you will have the B2B charging as you are driving along and the solar charging when you are parked up. You then have the best of both worlds as both batteries are being charged simultaneously making more power available at any one time.
