Best advice so far. Use an Isolator on battery negative.Lithium has minimal self discharge and should sit happily doing nothing for months, some say leave it at80% it is better for the cells. Keeping it at 100% is probably best avoided. The engine battery is more likely to drop and need attention.
I can check my engine battery using my tracker app and get texts about my leisure battery from my Truma iNet box.My starter battery is now at 12.7v and yes, I do have a B2B built into the Victron setup.
I could leave the B2B to look after this from the Lithium battery which is over 13v and would be better left at 50%. but I'd worry whether the starter battery dropped below 12.7v
It would be great if I had remote access to the battery conditions, like I coud read them on my phone and even get warning texts.
The fitting of a Battery Manager or a Battery Master between both battery banks, would help to keep the starter battery topped up.I could leave the B2B to look after this from the Lithium battery which is over 13v and would be better left at 50%. but I'd worry whether the starter battery dropped below 12.7v
I assume that's the job of the Victron b2b or am I missing something?The fitting of a Battery Manager or a Battery Master between both battery banks, would help to keep the starter battery topped up.
Either are easy to install and gives you piece of mind.
Cheers,
Jock.
That's a thought. My tracker tells me if the battery is low. I'll check whether the app lets me see the battery state.I can check my engine battery using my tracker app and get texts about my leisure battery from my Truma iNet box.
On my Voda app the information is hidden on the menu under the Device heading. Took me a while before I realised I could retrieve the voltage that way. To get the latest voltage I have to first get the app to refresh the vehicle location and then refresh the device data.That's a thought. My tracker tells me if the battery is low. I'll check whether the app lets me see the battery state.
A B2B, Victron or any other brand, charges the leisure battery from the starter battery/alternator when the engine is running. Typically they are 30A or more, up to 120A or even 140A.I assume that's the job of the Victron b2b or am I missing something?
You learn something every day. Looks like I need a seperate Battery maintainer.A B2B, Victron or any other brand, charges the leisure battery from the starter battery/alternator when the engine is running. Typically they are 30A or more, up to 120A or even 140A.
A battery maintainer, like the BatteryMaster or similar devices, trickle-charges the starter battery from the leisure battery when the engine is stopped. Typically they are about 1A or 2A, maybe up to 4A. It stops the starter battery from gradually losing charge when the MH is parked up for days or weeks.
strange replying to my own post but the controllers are Votronic duos that have a second battery position that charges the starter battery obviating the need for a battery maintainer/ master.I Have 2 victron duo controllers one for a 330w panel (switches off solar to controller) the second 100w 120w has a switch to battery whilst it charges the starter battery
Which was the suggestion in my post above. It's a fit and forget solution to maintaining a trickle charge to the starter battery, especially so when an alarm is fitted, causing a parasitic drain on the starter battery.You learn something every day. Looks like I need a seperate Battery maintainer.
Yes, I picked up on that. Obviously my knowledge of these system is pretty poor. Can I assume that as you say these are easy to fit that I with my limited knowledge could manage to pick this up.Which was the suggestion in my post above. It's a fit and forget solution to maintaining a trickle charge to the starter battery, especially so when an alarm is fitted, causing a parasitic drain on the starter battery.
Cheers,
Jock.
I would say so, ie, 1 x wire to the Starter Batt Pos, 1 x wire to the Leisure Batt Pos, and 1 x wire to earth.Yes, I picked up on that. Obviously my knowledge of these system is pretty poor. Can I assume that as you say these are easy to fit that I with my limited knowledge could manage to pick this up.
Battery to Battery charger, abbreviated to B2B.Lost me at b2b
Thanks. will find out and order one.I would say so, ie, 1 x wire to the Starter Batt Pos, 1 x wire to the Leisure Batt Pos, and 1 x wire to earth.
Similar connections may be closer to the distribution box, or at your B2B perhaps.
Once good connections are made, either of them sorts themselves out, with the CBE unit trickling up to 4A.
Be aware though, there is a newer version for Lithium now, which I have only recently become aware of. Hopefully autorouter, Raul, or Lenny HB can advise further.
Cheers,
Jock.
Do you know if my Victron easyplus would work the same as your multiplus?Some pp, use the battery master with Lithium with no problems. Some don’t like it and use the abelmail, I think I spelt it right. Abelmail is specifically to use with Lithium leisure. I use none of them. I have a multiplus, and on pcb, there’s a spade connector for a second battery, up to 4a. I use that with great results.
Thanks. will take a look at manual first.Yes it does, a EasyPlus it’s a multiplus with AC distribution added on. If you consult the multiplus compact manual, you will be able to identify the auxiliary battery charging point on pcb.
It looks like a spade connecting point low to the left if I remember right. If you don’t find it, let me know, I wil, take the cover of mine and take a snip as it’s connected.
