Condensation on garage doors
POH
Pilote 740c
5 years
Does anyone get condensation around the edges of your garage doors and on the inside trim , do have a heating outlet in the garage but yesterday it was closed so can't understand why reason for it , cold inside cold outside , so have opened it tonight and will check tomorrow .
Assuming the trim is aluminium then that's quite normal as it will be transferring the cold from the outside so when it meets the slightly warmer air inside condensation will form.
I get condensation everywhere at this time of year. . No way to avoid it if using heating.
We get condensation around the window shuts, heating on in colder weather in evenings, cooking, two of us plus dog breathing so it’s not surprising!
As Minxy says a cold aluminium trim is probably to blame. I wouldn’t worry about it, if it didn’t dry up naturally in the morning I would wipe it down. People create moisture, put them in a small warm box called a motorhome and in cold weather the moisture is likely to condense on any cold surface. I expect a little condensation in the winter, when away and at home (single glazed metal windows). It is really only a problem if the condensation is in the wrong places.
This is a perennial problem with the Le Voyageur. I place silica gel bags in the garage at the bottom and regenerate them as necessary. I am also suspicious of the door seals but cant find anything obvious and the rubber seal profile is unavailable
Try these people https://www.sealsdirect.co.uk/
My garage doors have a small lip in which the rain collects so that when I kneel on the entrance to get something out I end up with soggy knees.:mad:
Me too, even worse if you sit down to open the electrical cabinet. At least it doesn’t come through the seal and make the garage wet.
