- Apr 13, 2019
- 2,207
- 51,214
- VW 2005 T5 Campervan
- Since September 2018
Ok, so here we go.
Please forgive if this is a basic misunderstanding, but I am completely out of my depth.
We have a 2 year old Dometic 12v compressor Fridge, a new 100a Lead Acid leisure battery and a 10 amp battery charger and a 240v mains consumer unit with trip switch.
With the leisure battery at 12.7v, the compressor fridge when switched on starts and runs to cold after about half an hour but takes the leisure battery down to about 12.4v. If I leave the battery to get any lower than 12.4v the fridge then stops working.
If I switch on the main 10a charger to charge the 12v leisure battery and also switch on the compressor fridge, the fridge will run again for about half an hour, and then stops working, but is again cold.
My question is:
Is the compressor fridge,(a dedicated 12v unit), capable of being run on 240v via ehu IF the 10a charger is charging the battery at the same time, OR is the fridge only running still on 12v despite the battery showing a charge rate of 13.2v (ie the consumption of the 12v for the fridge is greater than the level and speed of replenishment from the 10a charger.)
Or, is it just not possible to run a 12v fridge this way via 240v and a charger, and if so, is there any way it can be so.
I am thinking that when on site I may want to run the fridge constantly , but as I do not have lithium or solar, this can only be done via ehu.
I believe the 12v compressor fridge is predominantly , and favoured, for off-grid use.
I will read the responses with interest and get back with probably more questions, but I am getting a bit frustrated with what I would perhaps think is a logical path, but then this is electrics and I am no Einstein.
Many Thanks.
My question is:
Many Thanks.
