I would say that the compressor fridge would work better in hot places, plus you would be getting good input from your solar.We occasionally use ours on gas for 3 or 4 days at a time in hot places, not sure how well a compressor would cope? Don’t like the idea of listening to it at night either.
Hi.We have seen a PVC we like but it comes with an electric fridge. Is this likely to suck the life out of the battery, (200Ah), if we go wild camping.
If anyone has experience of compression type fridges, I will appreciate comments on battery drain.
...and, no need for big holes in the side of the van.Compressor fridges have 3 other advantages -
More reliable than 3-way absorbtion ones
No need for servicing
More tolerant of levelling (lack of)
Yup Just fitted one to our classic vw.Found one the right size and only the 12v to connect up via a fuse but that was already in place from the 3 way.30 mins topsAre these an easy retrofit?
Hi, given the 200ah is lead, you have a decent 100ah to use every day, providing you have the means to charge back up.We have seen a PVC we like but it comes with an electric fridge. Is this likely to suck the life out of the battery, (200Ah), if we go wild camping.
Seems the industry has decided for me, but I’m encouraged by the comments here. I’ll have a 150w solar panel but don’t really have the space (or payload) for a 2nd leisure battery and not wealthy enough for lithium. At least I won’t need to bother with fridge vent covers blowing off!
Night mode sounds good (if it works) just need to ensure I incorporate that feature as I guess it’s not on all LV compressor fridges?
Hi Pete i have found from experience that outside ventilation would be required to be economical....and, no need for big holes in the side of the van.
Pete
Mine vents internally via a floor level opening and a grill to the wardrobe. I enhanced the air flow with a 120mm computer fan, works a treat. As for noise, I can't hear mine at all.Hi Pete i have found from experience that outside ventilation would be required to be economical.
The better the ventilation the better it works.
ThanksYup Just fitted one to our classic vw.Found one the right size and only the 12v to connect up via a fuse but that was already in place from the 3 way.30 mins tops
