Combustion air temperature sensor replacement
auto sleeper
Had E504h error on system, found out from Truma that this is the combination air temperature sensor and it needs replacing. Can anyone advise where I can get one(and if I can fit it myself) or my nearest repair place that does this sort of thing. I am in South Wales area. Cheers in advance.
The people you spoke with at truma should be able to let you know where to get one and you may be able to find a capable travelling hab survey guy. They are often trained / certified by truma. Hopefully someone with better info will be along after this bump.
