Clutch help
Dundee 🏴󠁧󠁢󠁳󠁣󠁴󠁿
fiat ducato 2.8 jtd
Hi folks , mechanics putting in my reconditioned gearbox today so I thought it makes sense put in new clutch ! I got one for £165 from Dingbro motor factors & unfortunately not lining up the pressure plate different size than old one !
I called motor factors back and can’t find my van on their system ! They just gave me a standard lucas 2.8 jtd clutch for a Ducato !
Any help asap be much appreciated 👍as mechanics at a stand still 🙈
Ryan
Ryan
Has the old parts got any identification numbers on them that the motor factors can use?
What diameter is it? there were 2 different size plates - depending on year
235 and 242 mm acording to a post on the fiat forum
To be honest, if the mechanic is worth his salt, then he’ll know exactly what plate you need, by comparing the old one and the new wrong one. Also, he should be able to source one from both the chassis and engine numbers and VRN for you. There should also possibly be info on the old plate. Make sure he changes the slave release bearing as well.
Good luck 🤞🏻
Smaller plate (235mm) fitted to jtd prior to june 2001.
What year and month is yours?
Good luck 🤞🏻
There struggling to get a match as van 2002 and nothing on there systems or auto trail
( model it is ) 🛑
( model it is ) 🛑
your motorhome may well have been registered in 2002, but chassis/engine etc could have been from the previous year, what does the plate measure across?
Hi clucth plate across is - 235 mm
New one I received was 240 mm
have a quick read of this - includes part numbers. post number 4
would seem your clutch plate is the 'older' (pre 6/2001 model)
