Ridgeway
Drying clothes (usually towels, swimwear and cycling gear) is easy enough in the summer (most of the time) however there are tomes when either A) outside it’s just too wet (yes i was back in the UK recently..) or B) you’re just moving around too often to bother setting up an outside dryer.
We used to hang clothes in our shower that had a small pop up roof vent and that sort of worked as the air flow as you drove along hepled although if you needed top use the shower then i created more work to empty it etc.
Wondered about setting up 2 washing lines tight to the ceiling in the garage as in ours it gets quite warm although there’s little air flow in there.
Any other bright ideas and what does everyone else do ?
