Cleaning van roof
Hi everyone my vsn roof is filthy. Soft cloth will not vutvit. How abrasive can i be to remove stains.
Spray it with "Wet & Forget"
I would turn off your predictive text as well. :ROFLMAO:
Spear & Jackson - Spray and Leave Concentrated Mould, Algae and Lichen Remover 5 Litre​
Good as wet & forget & a lot cheaper £15.99
Amazon​
We found our microfibre on a pole cleaner wasn't doing job, so have got a soft bristled brush on reccomendations from on here. I'll try that with a better foam on Weds, and apply Jenny chem when we return next week if it doesn't clear the spots.
We got the brush from a caravan place in Bridlington for around £10, but the bristles it's hard to explain, but they are not hard and not super soft either, desiend to be perfect for caravan/motorhome roofs (it has a water connection too to assist with lubrication). The plan is to foam the roof for 10 mins with a decent foaming cleaner, then brush (no water) then brush again (with water).
Amazon​
Just had a look at what is in it, no way would I get that anywhere near my Motorhome.
Can i use on the solar panel ?
No, It's just glass, so clean it like a window.
We use a telescopic squeegee, designed to clean lorry windscreens. (About £10 off ebay)
Every couple of weeks I stick a head and arm out of the roof top hatch and wipe down the solar panel.
It often doubles the solar input!
The solar panel needs to be wiped down regularly.
Spear & Jackson Spray and Leave Premium UK Manufactured Brand - Removes algae, green mould, and lichen Designed for use on patios, roofs, fencing, UPVC windows, sheds, caravans, boats, decking and driveways Treated area can be used as soon as it has dried Helps prevent re-growth see results that last for months.
Have looked at what's in it. No way would I use it.
