Cleaning solution prior to Silkaflex application
North East, UK
Elddis Accordo 105
Whats the best cleaning solution to use prior to resealing using silkaflex.
Also is Silkaflex the best stuff to use?
Ian
I would recommend roughing up the surface with course emery say 120grit before using solvent and then apply sealant
It gives a rough surface to key into
A lot of Sikaflex products are combined adhesive and sealer, so would not be ideal for re-sealing applications. What are you attempting to re-seal?
Geoff
Panel wipe. Acetone.
Be advised, clean the area before applying any masking tape, any of the cleaning agents will almost weld the tape to surface.
Mike.
Geoff
I have 2 jobs for it.
1. Using it to stick some brackets so I can attach a couple of rear mudguards, as well as screwing them on
2. Sealing underside of gas locker floor where it meets the side of the van.
I was hoping 1 product would suffice.
I know that Elddis use a Heinkel product but cant remember if it was a combined product like the silkaflex.
What would you recommend?
I would say Sikaflex 522 appears to be suitable for those jobs.
Geoff
Sikaflex Activator is Isopropanol (Isopropyl Alcohol) otherwise known as rubbing alcohol.
This should be suitable Isopropyl Alcohol 99.9%
