Clean sealant
Adrian140974
Middlesbrough, UK
Adria Supersonic 890
Minor question but any advice how to get external sealant between panels white again? Also the external rubber trims
Try this but on a small area first. Works great in our bathroom and on the last van
Cheaper elsewhere
Will be watching this with interest? I have found a little Ciff on the rubber seals works with a bit of elbow grease however never found a good way to keep them clean as wax seems to propagate a pinkish sort of fungus to appear after a few months🤔
Cheaper elsewhere
Never used it on motorhome but cleaned a very badly marked bathroom ceiling with it before applying Zinsser emulsion. 5/6 years on and still looks pristine.
Got it in Wickes.
Thanks all, I will give one of the suggestions a go.
Try this cilit bang black mould remover or any of the other products mentioned, roll up toilet paper like a cigarette hold in place soak it it will hold when wet leave over night.
Try on silicone in your home bathroom with bleach, I think you will be pleased with the result. ALWAYS CHECK A SMALL AREA FIRST.
I use the auto glym on all my rubber, window surrounds and plastics, it’s flipping brilliant, but won’t get the sealant white.
If it's just dirty use Tcut on a wet cloth. If it's mould use a product particularly for mould but often it's under the surface so may not come out.
