Citroen Relay - issue with resetting date/time on dash display
Pete Worsey
Citreon Relay Conv
Hi folks, new to the forum. Just picked up a used Citreon Relay 2018 conversion. Really happy with it but one thing is that I am not able to change the date and time on the dashboard display using the mode function button. It doesn't give this as an option on the menu and their are other options not available.
Anyone faced similar issues with this or a Peugeot Boxer?
Pete
Hello Pete Worsey , If you cannot find the date/time change option using the mode button , with the ignition on , do you have a touch screen audio system ? if so you , may need to use its menu/screen to set things up , instead of the mode button . (Peugeot Boxer)
Pete
My 2017 peugeot based has a time/ date change function on the mode button to the right of the steering wheel. Just click on the date/ time and use the up and down arrow buttons to change.If there is a time and date showing it must be possible to change them.
Won't change if your moving. I have changed it with engine running....i think. Peugeot Boxer)
The problem is I don't have the date/time option on the menu. I think it may be because the original factory fitted radio has been replaced. Will consult a Citroen dealer. Thanks anyway
Just seen this. Your probably correct it seems the date time rest is on the radio facia
If you decide to fit the correct radio and you need information about settings through the touch screen system on your 2018 Citroen Relay it can be found on page 92 in the Citroen Relay owners handbook.
