Citroen Relay H2L2 Awning
tonywl
Somerset, UK
2022 Citroen Relay
Since 2021
Hi there.
Just bought a converted '22 Citroen Relay H2L2 and want to put an wind out awning on it. Thinking of a Fiamma F80s 320. Is that a good choice?
I'm reasonably practical so am I going to be able to fit it myself?
Lastly, they list a 'standard' and a 'low profile' roof bracket for it. Which one is better?
Thanks.
I converted my L3 H2 and fitted a fiama wind out,being tight I made my own brackets,they are no problem to fit but you do need to Bolt through the roof,also the canopy support brackets come with nuts and bolts but can either left off or fixed adequately with stainless steel Self tappers,I could check the measurements of the 2 types of bracket if you have them(against my van).
If you use the Fiamma brackets then it’s an easy job as they just bolt onto the existing lugs on the roof, the awning is also easy to fit.
I can see the benefits as a sun shade, but I'd really like to know if they give benefit as a rain shade before spending a grand on one.
