Citroen Rapido 7092D, Where's the Leisure Battery?
PaulThw
I live in France and the nearest dealership is quite a way. I've found the vehicle battery but the Handbook I have gives no clues as to the location of the leisure battery. Any ideas?
Have you tried looking under the bench/seat in the living area? On the 8096dF it is under the bench seat immediately above the outdoor locker hatch to the electrics panel, so keeping cable run to a minimum
Definitely check under all the lounge seats, on our 10001 they are under the seat immediately behind the driver's seat (LHD) but all the control gear and charger are in the rear garage about a 6m run for the cables :(
Chears Sheddy & NRM. I'd already looked under the lounge seats but, following your advice I took another look. If you remove the seat covers, then another box covering some pipework, there's a side hatch which reveals the battery! It's as if the manufacturer is trying to hide it. Thanks again
