Cigarette Lighter soocket always on
EdRedBird
Silverstream, Tyholland, County Monaghan, Ireland
Transit Conversion
N00b
So with some devices plugged in on these sockets my starter battery drains on the transit
I could go over (un)plugging all devices each and every time but .... nope
1: Should these sockets be always on
2: Could I (probably by pulling new cables, power them with a relay via engine on
3: I had a look at 2 ...how do i pull the f ers out without damaging the dash
Option 4 install extra sockets as option 3
Sockets are often always on. If you are plugged in but the device is switched off there should be no current drawn.
A switched live could power a relay to put in a new socket. That would be fairly simple.
I would consider running any new sockets from the leisure battery rather than the vehicle’s battery.
I can only comment on my Mk7 coach-built, the one in the dash next to radio is always live and the one in the cupboard Infront of the stearing wheel is also always live. As mine is a 2.4 it has 2 starter batteries under the driver seat. I always unplug those 2. I also had a battery drain when fitted an aftermarket stereo with an eBay wiring kit. Ford to iso. The connection were wrong from electric Arial, steering wheel remote and alarm. (functions I never used) . Took me months to sort that problem.
