That's what I use, & rarely seem to need chocks because I angle the ramps so once 'van is level it's not under more pressure to roll off that handbrake / gearbox can't hold.
Downhill side??If you put the ramps on the downhill side, you'll not only give your clutch an easier time climbing on, you'll not need much force to hold the van in place.
Exactly what I was trying to say!!If you put the ramps on the downhill side, you'll not only give your clutch an easier time climbing on, you'll not need much force to hold the van in place.
When trying to get level on a pitch on a slope, first go up the slope, put ramps at the lower end of the slope then drive down onto them. As the front of the van goes up the ramps the back of the 'van goes down the slope. One up + one down = more balance & less stress on the mechanicals.I don't understand this. Can you explain it, please?
Still don't get it, tried to visualise it but can't see how you go up the slope and drive down to them and the front goes up .When trying to get level on a pitch on a slope, first go up the slope, put ramps at the lower end of the slope then drive down onto them. As the front of the van goes up the ramps the back of the 'van goes down the slope. One up + one down = more balance & less stress on the mechanicals.
If the van is pointing down hill, put the ramps in front of the front wheels. If the van is pointing up hill, put them behind the back wheels and roll backwards.Still don't get it, tried to visualise it but can't see how you go up the slope and drive down to them and the front goes up .
I meant 'the front of the van' to mean the end that's at the front when you go down the hill (slope). That's the back if you went forwards up the slope in step one. if you reverse up the hill then the end that goes up the ramps is the end with the headlights but if you go forwards up the hill the front of the van when you go down the hill is the end with red lights on in which is back of the van when you're on the motorway but the back is the front when you're reversing down the slope but when you're adjusting for a lateral slope you have to use a ramp at the back and the front but ondy on the low side which is usually the port side but only if you're in the northern hemisphere if you're in the southerl hemisph're I can't help because I've never been but I expect it's the opposite. Guigsy might know. Or know somebody who knows.Still don't get it, tried to visualise it but can't see how you go up the slope and drive down to them and the front goes up .
It's done by reversing up the slope, so the front end is down and the back end is up. Then put the ramps in front of the front wheels and drive up onto them. As the front end goes up the ramps, the back end will come down the slope
Ahh it's easy when explained rightIf the van is pointing down hill, put the ramps in front of the front wheels. If the van is pointing up hill, put them behind the back wheels and roll backwards.
