Langtoftlad
- Apr 12, 2011
- 9,240
- 159,380
- WildAx Aurora FB [PVC]
- Since 2015
As some of you might know, I've not used the van this year because I couldn't face it without Kerry who I unexpectedly had to put to sleep in January.
So, I noticed today the control panel was reporting the vehicle battery a very low charge
I admittedly have been very remiss about putting the van on hook up.
The engine fired up straight away, 1st time [after I remembered to disable the MetaTrack] but I got the dreaded "Check Airbag" warning.
I'm presuming I've knackered the module due to the low vehicle battery.
I know Crashdata* will repair said module for about £85 but I don't have the tools to remove it.
[*and apparently the fault can reappear]
Apart from spending a lot of money at Citroen, what are my immediate options?
Can I drive it with [safely] with the warning?
If so for how long
I understand it's an MOT fail.
I'm having some maintenance done at the end of August [new leisure batteries & fridge 240v element], so could it wait until then?
As the 7 yrs old leisure batteries are being replaced, would it make sense to also replace the vehicle battery?
The van is on hook up now, so I'll see what the voltages are in 24/48h
If so for how long
