Cheating at the T&G look...
Wissel
Horncastle, UK
Van Conversion
Since 2006
I have a van that needs to have the T&G look on all the walls - but no way I'm fitting T&G boards as they will warp at some point.
I was going to router them myself, but a lot of work making sure all lines line up with a board next door. So I cheated:
Now I've just got to biscuit joint them, fill any gaps, then spray painted.
Used it a lot of times and works well. You can buy with groves up, or across the sheet depending on what you are doing.
The fully cut panels. Very happy with these:
Bit of a sand, then in they go (will be sprayed in the van).
