Chausson flash 04 waste water
Chausson flash 04
Hi our motorhome waste outlet is at the rear under the number plate, a pull out t shaped handle, it has a slight leak is there a seal I can buy and replace, and where can i buy one thankyou
IIRC…..It’s either a 1 1/2” or 1 1/4” blade valve held onto the tank with 4 screws.
I think it will be a replacement valve rather than seal I would think.
You could try treating the existing seal with rubber treatment or silicone spray.
