Can I switch on my car and idle it. Will it charge the leisure battery if so how long do I run it for!
Ohgood job I checked someone on site suggested I could!!!!!Time needed depends on your relay/charger system and what rate it can charge at.
If for example your 100Ah lead acid battery is at 50% you need 50Ah. My van's pathetic charger max is 12A. So I need some 5 hours to refill, even if driving.
But idling a diesel, especially if from cold, can cause problems for the engine. Modern diesel dpf filters will bung up. You can "glaze" piston bores. Bottom line recharge by idling on a site us emergency only.
What's a b2b device?If you want a fast charge whilst engine is running (driving to site) then look at B2B devices
If the battery is a lead acid then 12.75v is about 90% charged.It's leisure new battery but no sun so power gone down to 12.75? Is that okay? What's the lowest it can go safely?
Brilliant thank you have screen shot !!12.7 is normal fully charged voltage of a lead acid battery so as a result it is likely that your solar controller has reduced the charge accordingly.
Have a look at this chart
Fully charged voltage depends on what type of lead acid battery you have but if you used electric yesterday and your solar isn't producing anything today and you're not on hook up then how has your battery re-charged ?Brilliant thank you have screen shot !!
