I'm in the process of upgrading to a LiFePo4 leisure battery - along with a mppt solar controller & B2B charger.
MH is a Bailey Autograph on a Peugeot cab.
As the Victron SmartSolar controller only has 1 battery outlet, I need to find a way of charging/maintaining the starter battery, and just to complicate things also whilst the Pug isolator is in operation (parasitic discharge is too large if battery not isolated) during the Winter - at present the MH goes on EHU for 24hrs once a month to charge both batteries - but with a LiFePo4 leisure battery this probably won't be required. So was hoping to use the leisure battery to maintain the starter battery (leisure battery is permanently connected to the solar panel, even when hab. electrics shut down).
Vanbitz battery master only has 1 negative lead, does anyone make one with 2 or do I need to do something else.
