Thank you. Great info.Hi
Yes, 99%? of Motorhomes have an in built charger, often as part of an overall electric control system.
You should have a box of tricks somewhere with switches and fuses on it.
The charger supplies your leisure battery with 12V+ and in turn your battery supplies your 12v sockets and devices like spark ignition, lights, water pump, blown air heating fan etc.....
Get yourself a cheap multimeter. Set to DC. Measure battery when everything is off - a full battery is about 12.8V. now turn on EHU and your charger - voltage should jump at battery to 13+ volts to show it is being charged.
Don't fear asking questions here. But do use the search button too. The more you understand How These MH work the less stress you have that day you flick a switch and things don't work like you expect them to.
