Changing wiring route. (1 Viewer)
jumar
3,695
11,215
Spain
Hymer Tramp
Since 1994
Morning...my Solar Panel is routed via a MPPT controler to charge my one leisure battery, and its efficiency is good, but my Engine battery is lacking charge after being stationary for a couple of weeks,
the battery is 1 year old, I do not have access to 220v where the van is parked....running the van is currently my method of topping up the battery.
Can I route my cables to charge my vehicle battery at the same time as my leisure battery, my vehicle is a Hymer Tramp, with an Electoblok fitted....don't want to fiddle before I ask.
Two on Tour
10,212
49,914
Elddis Autoquest 175
Since 2010
Why not fit a Battery Master or similar device, a lot less faffing about.
https://www.vanbitz.com/product/battery-master/
upload_2019-3-13_17-32-29-png.289664
upload_2019-3-13_17-32-44-png.289665
Apr 27, 2008
11,794
13,956
Eastbourne East Sussex
Hymer low profile
Since 1972
Or a voltage controlled split charge relay £15 from ebay. Only works one way round of course but has been working fine charging auxiliary battery on my Land rover for a year or so.
Don Quixote
2,966
5,257
Lost in La Mancha, Spain
VW T6 Campervan
I second the "battery master" it's fit and forget and takes very little time to hard wire in. I bought mine direct from Eddie and arrived in no time to Spain.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Your MPPT controller may well have the terminals to go to the starter battery in which case it would be pretty easy depending on cable routing, otherwise yes the battery master from Vanbitz or Votronic will do the job and may well be an easier cable routing job (I know mine was).
Martin
SandraL
1,373
985
Somerset
Hymer b694sl
What type of elektrobloc?
If you have a solar controller able to output to starter as well as leisure often the electrobloc provides an easy way to send that power to the starter battery.
Nasher
2,094
7,178
Pontardawe
Pug Boxer
Since 2013
As others have said, you may have the facility on existing controller to charge the vehicle battery - if not, or if it is difficult to connect/wire in - then the Battery Master (discounted for funsters) is a good, easy fit solution
Minxy
32,489
66,026
E Yorks
Carthago Compactline
What make/model of MPPT have you got?
jumar
jumar
3,695
11,215
Spain
Hymer Tramp
Since 1994
ELB 100 . Victron Mppt...64...
SandraL
1,373
985
Somerset
Hymer b694sl
Ebl 100 doesnt support solar charging of engine battery.
Couldnt find a victron mppt 64?
ps thanks for taking me walking at Totana!
jumar
jumar
3,695
11,215
Spain
Hymer Tramp
Since 1994
Thanks guys and gals....I am going down the route of a Battery Master....just need it sending across the water to here in Spain.
Nov 6, 2008
3,943
40,800
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
I fitted a battery master (similar) to my US RV, excess charge from the leisure batteries goes to the chassis battery, and it has kept it charged very nicely.
Craig
jumar
jumar
3,695
11,215
Spain
Hymer Tramp
Since 1994
Craig
Hi Craig....what's similar....I take it you are referring to an alternative...
Jumar
