Hi im wiring a cbe system with a ds-300 board and a pc-200 panel can any one please tell me what the 12 pin plug called masses is for please many thanks vince
'Masse' is a chassis connection, ie 12V negative. So the Masses connector is a bit like a negative busbar, except it's a connector. 'Terre' is a ground/earth connection, as used for 240V mains supplies.
