- Apr 15, 2015
- 664
- 1,195
- Carthago E-Line 50
- Since May 2011
I'm exploring the possibility of putting a B2B charger on my Carthago, but I understand that I'll need to disable the existing split charging unit. Does anybody know where it is? Is it a separate unit, or is it built into the electronic gubbins in the boot? I can't even identify a fuse for it. Is it likely to be an ordinary automotive fuse, or one of the midi fuses which are attached to the multi-connector that is on the +ve of the vehicle battery?
It's a Carthago 5.5XL but I think the electrics are the same on all the 'A' classes. Electronics are CBE
Might even consider a Votronic triple unit (mains/B2B/solar), although they're a bit expensive.
Thanks in advance.
Thanks in advance.
