Carthago passenger door window controls.
North Yorkshire
since 2000
We have downsized slightly from E Line to a Lightweight C Tourer. It has a very obvious specification difference, but we are getting used to that.
I can’t get over the logic of the passenger door window. The E Line had a control on the door and on the drivers side dash.
I can cope with just one button on the passenger side, but I can’t understand that it will only work with the engine running, not just with the ignition on.
Does that sound correct to anyone or do others think it’s a wiring fault?
I have a C-Line with the window control on the door, no control from the drivers seat, unless you have two metre long arms :rolleyes:. The window does however work with just the ignition turned on.
My Geist is the same. I think I get 30 seconds where the window works after the key is pulled.
On mine, the mirror control is also on the passenger side. 🙄
Depends which is the passenger side! :giggle: We have a mirror control on our passenger (UK nearside) which is a 'dummy' ... totally flummoxed us when we picked the MH up originally ... why they didn't just remove the switch and 'cap' it I haven't a clue.
