I am arranging for lithium to be installed, and me being me, just double checking the battery space etc. Although not directly related to what I am doing, I cannot understand why it has two chargers installed- could someone answer this please?
I managed to get three 100ah lithiums in mine (same model as yours), but I had to build a wooden platform for one of them to sit on top of the wheel arch.I am arranging for lithium to be installed, and me being me, just double checking the battery space etc.
Thanks, yes I have three 80ah gel at the moment, and the far one is on a step, I am going do 1-460ah fogstar (522mm long) and just wanted to double check it will fit before the step, which it does- just!!I managed to get three 100ah lithiums in mine (same model as yours), but I had to build a wooden platform for one of them to sit on top of the wheel arch.
I’d perhaps consider two batteries instead of one. If you only have one and there is a fault (with the BMS for example) and it closes down, you don’t have any 12 volt power. Two batteries provides some redundancy as they probably won’t both go wrong at the same time.I am going do 1-460ah fogstar (522mm long) and just wanted to double check it will fit before the step, which it does- just!!
Yes good point, I will discuss the pros and cons with the installerI’d perhaps consider two batteries instead of one. If you only have one and there is a fault (with the BMS for example) and it closes down, you don’t have any 12 volt power. Two batteries provides some redundancy as they probably won’t both go wrong at the same time.
Yes they are, they go back under the bed area, below the floor, it is the tag axle (DA) model, so I think that may be the differenceI was trying to figure out your install and looks like your batteries are under the controls in the garage, I have an i50 too. My battery is in a dedicated box between the hab door and the front wheel, I installed a single 280ah on its side and modified the original clamp bracket to keep it in place. View attachment 856852
Yes I realised that when I looked at your avatar, mine is the single axle.Yes they are, they go back under the bed area, below the floor, it is the tag axle (DA) model, so I think that may be the difference
We had a 51qb da before the S plus - with an L shape battery box I think. 460AH works for us, and we're not particularly careful with usage in spring summer etc. If the 460 gives enough discharge amps for whatever inverter or other users, you could always have a smaller backup next to it for the unlikely event of the big one failing. I did think the garage was plenty big enough to "extend" the box a bit if needed. We now have 550w solar, and 30amp B2B (soon to be 50), and rarely stay more than 2-3 days in any one place so tried to work on a 3 day capacity in the batteries......Yes they are, they go back under the bed area, below the floor, it is the tag axle (DA) model, so I think that may be the difference
Thanks, I only plan to use the 1800w dometic inverter, so amp draw should be enough, I only have 2x135w solar, but like you majority of time will only be 2-3 days.We had a 51qb da before the S plus - with an L shape battery box I think. 460AH works for us, and we're not particularly careful with usage in spring summer etc. If the 460 gives enough discharge amps for whatever inverter or other users, you could always have a smaller backup next to it for the unlikely event of the big one failing. I did think the garage was plenty big enough to "extend" the box a bit if needed. We now have 550w solar, and 30amp B2B (soon to be 50), and rarely stay more than 2-3 days in any one place so tried to work on a 3 day capacity in the batteries......
