Carthago 2015 Owners Manual
Not an owner yet.
We are in the process of buying a Carthago chic c line I4.9 A Class 2015 privately and the Motorhome doesn’t have any manuals. I have been searching online with no success. I was hoping that someone would be able to point me in the right direction to get an owners manual or equivalent? Thanks in advance and appreciate the knowledge available and shared on this platform, especially for someone new to motorhomes.
Thanks Lenny, I have tried and can only find the manual back to 2021. I have contacted Carthago directly however I have been told they are not the quickest to respond.
I have the same motorhome albeit on a 2016 plate (Facelift model). I do have a manual for mine but it’s quite thick, but if you want to know anything in particular gimme a shout.
Maybe try all the Carthago dealers to see if they have one lying around, Good luck with the hunt👍
Thanks Westy66. The one thing at the moment is the security for insurance, alarm, immobiliser and if Thatcham approved. I know the one we are buying has an Autowatch alarm fitted however I don’t have the certificate for it so will have to go with the base vehicle details until I can check out what is installed.
Autowatch is an after fit giving Thatcham 2-1 upgrade, certificate not normally required these days.
If it was a factory fit alarm it wouldn't be Thatcham approved.
I have a 2015 manual for an e-Line, but I expect most of the information would be common. Like WESTY66, if you want to know anything in particular send me a message or if you're in range of Bedford we could arrange a loan or copy or something.
TBH, even without the manual you should be able to get almost all the necessary information from the seller. My manual doesn't mention alarms.
Thanks all, excellent advice. I will try the dealers however I should be able to pick it up.
