Carthago 138 solar -starter battery fuse
Scotland
Carthago 138 Compact
Since 2017
Does anyone know where the fuse is between the solar controller and starter battery on a Carthago 138db. The twin solar controller is wired via the Carthago pre-wiring and was happily charging both leisure and starter batteries but is no longer connected to the starter battery. On the app battery 2 isn't there any more. I disconnected and tested the wires for battery 2 but there was zilch. The controller's panel battery 2 terminals showed 14.5v was available. I suspect a fuse has blown but can't find it and the owner's manual isn't helping. It's still under warranty, but if it's a fuse then I'd rather do it myself in case it happens again.
From the factory, there is a cable from above the fridge that goes to the front driver's side of the dashboard. The cable then goes from there back to the battery compartment. It all depends where the dealer put the control box. as to where the fuse is located. It's not a Carthago fit from the factory.
Regardless of where the controller is, the fuse should be in the battery compartment in the floor in front of the lh seat.
Sadly too much spaghetti going on in there for my capabilities! If I can't narrow it down I'll the dealer fix it!
