Riverbankannie
Has the adaptor been dropped and might be bent?Sealing it onto our outlet was fine just could not get nozzle to attach
I'm confused now (easily done nowadays) because having just gone to the Gaslow site to check the available adapters there's no mention of a German one. There is a Gaslow Euro adapter but that has an external screw thread.Sure you had the French one and not the German one as they're very similar and an easy mistake?
And I was replying to your post regarding Riverbankannie French adapter not fitting Carrefour pump.Sure you had the French one and not the German one as they're very similar and an easy mistake?
Not an answer to the poster’s issue but have you had any problems filling up with LPG in France? When we were there last year Total garages wouldn’t let you self-fill and off motorways, garages with LPG were few and far between.
Currently approaching Dieppe and hoping we don’t have the same problem with our French adaptor, assuming we find some LPG.
I’ve used that one but the only trouble we have is having to reverse out after paying because the kiosk height.We've used L'Eclerc at Yvetot in the past but you've probably gone past
Yes but you said you did not know there was a different one for Germany but whatever.And I was replying to your post regarding Riverbankannie French adapter not fitting Carrefour pump.
Not to our knowledgeHas the adaptor been dropped and might be bent?
Yes, the French one but of course we did get the other 2 out of the bag just in case !Sure you had the French one and not the German one as they're very similar and an easy mistake?
Now at Troyes, we carried on as did not want to spend too much time on it having read that the very nice municipal aire here can fill by 1pm.We've used L'Eclerc at Yvetot in the past but you've probably gone past
