Caravan porch awning on a van conversion
Van Conversion
3 yrs
We have a Citroen Relay L2H2 conversion with a Fiamma wind out awning.
We currently have a Kyham drive away awning which we love but on some sites we struggle to get on the pitches as it is 4m out from the van.
Had a couple of lectures on fire gap regs etc.
We have started looking at caravan porch awnings to cut down on width. Has anyone got any suggestions or recommendations?.
Jim
Jim
Hi, Jim I have a Kampa rally pro 330 caravan porch awning for sale £100 if interested pm me or tel 07726342244, it's only been used for 1 week.
Cheers Dave
ps I am in N cumbria
Reactions: f6c
We use a Kampa caravan awning as it was cheaper than the Air one that they make for motorhomes. The caravan version has the 6mm bead only which is too big for the Fiamma channel so you may have to use a fig. 8 section. I pulled out the 6mm bead and pushed in the smaller 4mm one.
Cheers Dave
Hi Dave.
Thanks for that. I will have a look online at them.
Jim
Thanks for that. The awning looks great on the side of your van, the same size as ours I think.
I notice you have had to leave the awning bead "wing" out of the Fiamma channel so it fits correctly with the sliding door. Is this a problem?. Also is there plenty of clearance with the sliding door?
Jim
Jim
Depends how far your awning is over the door, I moved mine as far as possible to the left to minimise the bit hanging out but it’s not a problem.
It’s not a problem with the sliding door also.
You can only fit the 2400 awning as the 3 bay one is too long.
