Cannot adjust speedo panel brightness
Elddis based on Peug
My 2018 Boxer (as an Elddis Motorhome) has digital slider brightness adjustment on the centre panel which works ok for that panel only. However I cannot find how to adjust the speedo panel brightness and it is is not on the 'menu' to the right of the speedo panel. Some online manuals show a button on the speedo panel shroud but there is none on mine. This is an issue since the speedo is hard to read on a sunny day. Where can I find that control?
Thanks, Nick+
Thanks, Nick+
Seems strange to say but, when I first bought my Fiat Ducato PVC, I found the dashboard hard to read UNTIL I removed the swivel on my driver's seat.
I never used it and it weighs a ton why should I carry all that extra weight around when the payload can be better used for other stuff, wine or now Cider for instance. 😄
I'm going to follow this post.I've a similar problem with my 2015 Boxer but can recall the Peugeot garage technician back in 2015/6 managed to brighten up the display BUT the ignition had to be on,not the engine.Since then the display has gone dark again but I now rely on Satnav for speed indication.
In another post somewhere,a novel solution was to use a small clip -on LED light to the top of the cowl and plug into lighter socket
Welcome to the forum.
Will this be the same as a Ducato speedo?
I seem to recall several posts about the unreadability of them.
