- Aug 17, 2019
- 4
- 8
- Iveco daily XLWB
The simple question.
If I wanted to power my workshop (which is currently connected to the grid, under TN-C-S arrangement ) from my campervan (TN-S arrangement), how would you install this? And do I need an "Earth Rod"?
Now for the more "in-depth" long question" and explanation of the proposed off-grid system.
With the help/ advice from Gromett (so I will tag him within this question), we've been trying to plan / work out a safe solution on how to do/go around this.
We both feel and agree this needs an 'experts eye going over the proposed way, in which I plan to install this'.
So if they are any experts who solely install 'off-grid applications', your advice/input would be greatly welcomed & appreciated
To be fair, my experience has really been with 'three phase industrial charging systems and industrial three phase busbars over the past 30 years' (MHE Engineering), and Gromett is a former electrician. So, as you can appreciate, this is not something we have done before, as it is an 'unusual bespoke setup / application'.
However! I think I should start with my proposed setup first, as this is neither a permanent installation nor a mobile installation but more of a mixture of the both ( probably the best way to describe and simplify the below installation is -
" a generator supply with TN-S arrangement connected to the workshop, but transfering and isolating the grids TN-C-S arrangement").
My workshop is connected to the grid, however! The grid supply is an TN-C-S arrangement which is coming into the property that it is currently connected to, I don't particularly want to change it to a TT arrangement nor add an TT arrangement for the workshop due to the implications of the grid supply (TN-C-S arrangement), nor can I share/connect to the grid TN-C-S earth arrangement with the off-grids TN-S arrangement.
Over the past 3 years, I've suffered with a lot of power outages to the property ( around 8 so far ), so I want an off-grid solution to deal with this involving the campervan as a battery bank.
My campervan setup.
Within my campervan, I have one 'Victron Multiplus ii, 24v 5000va. The DC power supply for the Multiplus is two Lifepo4 24v 280a Fogstar Drift batteries, ground to its own ground point upon the chassis ladder of the van.
Whilst the Multiplus is in off-grid mode ( island mode ), it is in the state of "an N-E bond arrangement (TN-S)".
How I propose to install this?
From the Multiplus (witthin the campervan), or from the AC-1- out to the CU (using 6mm2, 3-core H07RN-F cable). Within the CU, the circuit is fed through a ('ALL' RCDs & MCBs mentioned below and throughout are 'double pole Schneider RCDs & MCBs') 40a 30ma RCD and a 16a type b MCB.
(The Multiplus, the CU, and the off-grid output socket are all bonded to the chassis ladder of the van (using 10mm2 Earth wire), and any exposed metal surfaces have equipotential bonding).
From the CU and before entering the off-grid output socket, they will be another 40a 30ma RCD *(a backup RCD if the one in the van's CU should fail to trip).
From the second RCD onto the van's off-grid output socket , this is a 32amp isolated socket in order to plug the workshop into the van. Connecting the two will be a 6mm2 3-core H07RN-F cable with 32a plugs on both ends (van plug end male, workshop plug end female).
The cable above will be connected from the output socket of the van and the wall mounted 32a input socket.
From that wall mounted input socket is a 6mm2 twin and earth SWA cable routed away from it and clipped onto the wall of the house ( around a 5mt run ), where it will terminate at the automatic transfer switch.
The automatic transfer switch will disconnect the grid supply. So, thats the Live, Neutral & Earth (grid "TN-C-S" arrangement will disconnected / isolated) will be isolated from the cable run going from the transfer switch and onto the workshop CU, but only once the off-grid cable from the van is plugged into the wall socket and the isolator switch is turned on, (which is on the vans off-grid 32a output socket). Then, the vans off-grid feed supply (16a maximum, Live, Neutral & earth, TN-S arrangement) will be supplying the power supply over onto the cable run going from the transfer switch onto the workshop CU, powering the workshop.
On the grid input feed and the off-grid input feed on the transfer switch, they will be an individual 40a 30ma RCD and a 6a type b MCB dedicated to each feed before going through the relays and then onto the workshop cable run ( two Schneider iCT 25A 2NO 2NC 220...240V 50Hz contactor - A9C20838)
I hope I have explained the above well and in detail in trying to share with you and what Im trying to achieve here?
So my questions are.
Can anyone see any issues over my proposed way of installing this?
Because the off- grid power supply is coming from my campervan into the workshop, which doesn't have a earth rod (due to the N-E bond arrangement (TN-S) ) and supplying my workshop under a TN-S earth arrangement, do I need to install an 'Earth Rod' for the campervan ( the source ) ?
Any help, advice, or input would be greatly appreciated. Many thanks, Mark C.
My campervan setup.
