2019 Smart Car Auto also trip tropic can it be towed Thanks in advance
You can but your best bet is to follow the instructions on Evilution It'sls quite a complicated process if stirring the gear stick and pushing things2019 Smart Car Auto also trip tropic can it be towed Thanks in advance
You also have to press the brake pedal to ensure it goes into neutral.If it can be towed there's a sequence regarding neutral and ignition..... But I can't remember what it is.
Something about neutral not being selected unless ignition is on. Gear selector show neutral but it's still in a forward gear.
Once selected turn ign off.
If you get it wrong it's an expensive mistake.
LNB Towbars of Bristol have a range of trailers designed for small cars to be towed by motorhomes.Hi lads well done some research on this and in my opinion it is a expensive problem if the set up goes wrong going to buy a tow car manual gearbox thanks for your comments
Sorry. Late to the party. I agree with your decision regarding a manual car. We had the semi-auto Smart of a similar age. Religiously followed the sequence to get it into neutral before towing. Still managed to wreck the gearbox. Cost around £3.5k to replace and fix. Expensive lesson. Never again!Hi lads well done some research on this and in my opinion it is a expensive problem if the set up goes wrong going to buy a tow car manual gearbox thanks for your comments
