Babios
- Jan 6, 2024
- 5
- 1
- Clever Cleverly
In the bulk charging stage, the charger is indeed running 'flat out', at the full 16A. The charger is in 'constant current' mode, and electronically limits the amps output to that 16A value. It continues until the voltage rises to the absorption voltage, at which point a lead-acid battery would be about 80% full. So the charger is designed to run flat out for 80% of the charging.You can charge them on the Gel setting they will never fully charge also if charging from a low level often you could burn out the charger. When charging lead batteries the charge rate gradually reduces as the battery takes a charge. With Lithium the charge rate is constant until the battery is charged so the charger will be running flat out, something it was never designed to do.
To charge a 100 ah Lithium from 10% upto 90% about 5 hours but probably a bit longer as the charge rate will drop off as the charger gets hotter.
I agree in theory but in practice very few chargers charge at the max rate for very long for example my EBL will start charging at 17 -18 amps but after about an hour it will drop to around 14 amps and as the battery voltage increases further it drops to 12 amps and it's supposed to be a constant current mode. With Lithium the internal resistance is so low the charger will maintain full output until the battery is charged putting a high load on the charger.In the bulk charging stage, the charger is indeed running 'flat out', at the full 16A. The charger is in 'constant current' mode, and electronically limits the amps output to that 16A value. It continues until the voltage rises to the absorption voltage, at which point a lead-acid battery would be about 80% full. So the charger is designed to run flat out for 80% of the charging.
