campercontact help :-) (1 Viewer)
Jaws
23,827
72,279
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Just downloaded it and activated the free trial period.
Before committing to pay, I am a bit stuck and cold do with a pointer...
I did a brief check on a couple of known places, but could not see anywhere that gave the actual coordinates or any sort of map reference ..
As far as I could see the only option was 'directions' . Fine if you want to go somewhere and have a nice BIG data allowance but no good if plotting a destination for the next day..
What am I missing ?
Apr 22, 2018
6,806
12,541
Herts.
Adria Coral lowline
I don’t have the full ap (wife does that bit) but website shows coordinates
Apr 22, 2018
6,806
12,541
Herts.
Adria Coral lowline
Paul and Kate
2,090
11,027
Stoke on trent
Auto sleeper Warwick
Since 2015
I believe the free trial only shows a certain amount of stops when you pay it unlocks all the locations.
Jaws
Jaws
23,827
72,279
Thetford Norfolk
C class, Chieftain
The free trial gives you 7 days of use of the full app giving you a chance to try before you buy... You have to download the app and select start free trial :)
Jaws
Jaws
23,827
72,279
Thetford Norfolk
C class, Chieftain
Coughed up the lolly for the full version and downloaded all the off line maps we are likely to use
Lanerboy
1,363
2,206
midlands
Carthago 4.9 superior
I too have just purchased this app
My question is can you enter the coordinates into a sat nav as never tried this
May 7, 2017
1,945
2,265
Suffolk
2017 Chausson 718XLB 180
20 years
when looking at Coordinates how do you tell the difference between minutes and the metric version ?
Simon Richardson
212
139
East bound & down.
Carthago C Tourer 150 I
Full timing since Dec 2017
We just let the phone take us there via the App. I'm not daft enough to go under a low bridge or through a weight limit so it's always been ok.
klaatu
1,993
2,793
Vienne, France
Globecar Summit 640
Since 2014
The decimal degrees format is a single number with a decimal point in it, as in the first line in the image above, and the degrees-minutes-seconds format is three numbers normally using the degree symbol, the minutes symbol and the seconds symbol, as in the second line in the image above.
Sometimes, the degrees and decimal minutes format is used, e.g.
N 47° 59.5’
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Use the coordinate format that suits your satnav. If it’s a Garmin you can select which format you wish to use. I’m not sure about other makes.
Alternatively, download the poi files for the countries you will be visiting from the Campercontact website then upload them into your satnav. That way you can select your location in the app, then search for it in the satnav.
https://www.campercontact.com/en/content/downloads
