Guys been thinking in getting a dome fitted i have had a quote of £1,400.00 to supply and install is this about right
Bill :thumb::thumb:
Bill :thumb::thumb:
Bill :thumb::thumb:
Sounds like a good all in price, i have been considering getting one as well, who is offering it at that price?
Gary
When getting a quote make sure it is 'like for like' there are four models of Camos domes..
Prices from around £1200 up to £1700
30cm and 40cm static
30cm and 40cm in-motion
For the UK the 30cm is more than adequate .. further afield the 40 cm would be advisable.
Unless you plan to watch on the move, buy a static..
Installation is very straightforward requiring only one coax cable, run from controller to dome.. Bear in mind you need a satellite digital box, not included in price
£200 to install seems a little steep, should take no longer than a couple of hours for a competent installer.
Apologies if you know all this already ..
Thanks for that the quote is for a 40cm static does not include the box. question the control box is it 12 volt or 240 or both
Bill
I think the best thing about the Dome is that it isn't affected by the wind .. something nearly all conventional dishes suffer from ..
my Maxview crank up was particularly sensitive to this and had to be cranked down in windy weather.. just at the time when you are most likely to need it.. oh:
For those on a tight budget I think the the Camos crank up flat is a worthy contender, has had great reviews in both ease of operation and stability in wind.. it would be my choice if buying again..
Link Removed
Link Removed
I agree that its a lot of money just to watch tele when you can get a suitcase system for £60.
if you want to wait me and smith 123 are traveling through europe together for a month and we can do a like for like review on reception etc as i have the camos dome and he has the camos crank up plus
Facing the same dilemma, i eventually went for the Camos Plus Flat Sat with the slightly bigger 'dish' and twin LNB - this was a real 'must' for me with the HD+ box and something that further escalates the price of domes. The Glomex looks good value but doent seem to have a twin LNB model at present . After a few set-ups I can now find good old Astra 2 really quickly.
Having just returned from Denmark I was amazed that we could still watch BBC HD (hence Footie, tennis etc) on the west coast (Esbjerg) although not in Copenhagen. However, Sky sports and Movies were accessible for the whole trip.
Rgds,
Chris.
Hi, Could someone please explain - in simple terms - why a satellite will pull in sports and movies (pay channels) but not normal BBC etc?? A friend of ours in Santa Suzanna had a dome fixed to his new van and was assured it would work fine north of Barcelona. No chance, he could only pull in news and rubbish programs on his free view box, BUT when he rang and complained to his supplier, he was told if he had taken his Sky+ box he would have no trouble watching Sky 1, movies and sports, all the pay channels. This does not make sense to me, either you can fix on the satellite or you can't, what difference does the channel make??
Ginny
I found the range of our Camos Dome 40 for all the UK channels to be as far east as the edge of Bavaria, Northern Italian lakes, all along the med and just into Northern Spain on both the med and atlantic sides. At these extremes any bad weather such as heavy rain would break it up but otherwise its very good. You can of course tune it to other sats quite easily so it will work all over but mainly foreign rubbish
Because they are on different beams. UK FTA channels (BBC / ITV C4 etc) are broadcast on Astra 2D which has the narrowest beam / footprint. These channels are supposed to be available only in the UK but we motorhomers benefit from the satellite's overspill. Sky subscription channels are broadcast on Astra 2 North and South beams. These have much wider coverage (most of Europe). You can also get BBC News, CNN and Sky News on the South beam, but not the general programmes.
I am on a steep learning curve (sitting in Bavaria) with a relatively new Camos 40. I cannot get UK FTA here, but the news channels (and radio) can be pulled in on Astra 2 South.
Philip
I agree,
Weve had the flat sat plus for a while now and its spot on. I coudnt justify a fully automated system when I can tune in the flat sat so easily.
Jim
