Calibrating Goldschmitt levellers
Washington
Hymer B 584DL
17 years + 35 tugging
The handbook is in German. I've been all over the internet and this forum and can't find any reference to calibrating this make.
I've always known that mine aren't too accurate but now I find that they make the wrong decisions and end up saying " Reached the end of travel" without being level. So now I often manually level them with much better results.
INACCURATE? where the ground is only slightly out of level, using auto-level the levellers will operate and then stop saying the van is level when it is still a fair bit off. So I manually adjust.
WRONG DECISIONS? Say I am slightly down at the front but a mile low at the near-side. They start by levelling the front, which also lifts the OFF-SIDE front. Having done this they then try to lift the near-side and find that they run out of cylinder.................. I drop the front off-side manually and this brings the van near level, side to side and front to back.
Anyone know how to calibrate these?
I've manged to translate a section of the manual, and I hate Goldschmitt!!!:
kalibrieren des lagesensors bei der anlage muss der lagesensor kalibriert werden. dies ubernimmt die fachwerkstatt bei der ersten inbetriebnahme. erst danach kann der automatikmodus aktiviert werden.
TRANSLATION
Calibrating the position sensor The position sensor must be calibrated in the system. The specialist workshop will take care of this during the first commissioning. Only then can automatic mode be activated.
I have these, the instructions are useless!
I think the calibration has to be done from the phone app, have you set that up?
Just noticed in the app there are instructions in English!!
Once you are in the app, I think it is quite simple, you set to manual get level, then you can save the position, it will then always settle on that position.
Not sure if you are aware, but the app also has a weighing function.
I've found a Goldschmitt HLC app if that's the one. I'll try it out tomorrow.
Upvote 1
Connection is fiddly, n3d to have engine running, hazards on, and also has to be in gear!
Once connected and paired, it is quite easy after that.
