- Jun 29, 2015
- 4,361
- 70,017
- caravan (for now)
- on and off since 1984
6mm? if you are meaning 6mm2 (I think you are), then that is way way too small! I would also forget the circuit breaker and use a proper fuse (circuit breakers are notoriously poor unless you spent proper money on decent ones)Having now bought the inverter I have looked into the cable and fuse size, a 2000w load at 12 volts is approx 166 amps so I have ordered a 200 amp circuit breaker and 6mm cable to connect it.
People who know, is this right please?
Sorry I'm a bit confused, it's 16mm² I should also say it will never run at 2000w nearer 500w and only for a minute or 2.6mm? if you are meaning 6mm2 (I think you are), then that is way way too small! I would also forget the circuit breaker and use a proper fuse (circuit breakers are notoriously poor unless you spent proper money on decent ones)
The right size cable is a combination of the current being drawn and the length of cable. Without knowing both, impossible to say appropriate size cable needed.
What is the distance from inverter to battery? PS. Whatever it is, 16mm2 will still be too small.Sorry I'm a bit confused, it's 16mm²
I haven't worked it out yet but as close as possible, I should think about 300mmWhat is the distance from inverter to battery? PS. Whatever it is, 16mm2 will still be too small.
My guess would be still no where near enough, our last van was 80 mm sg I think and this one must be over 100.Sorry I'm a bit confused, it's 16mm² I should also say it will never run at 2000w nearer 500w and only for a minute or 2.
I'm well out I did check online and it gave me the numbers, I may have inputted it wrong or it was a dodgy site. Thanks I will get new cableMy guess would be still no where near enough, our last van was 80 mm sg I think and this one must be over 100.
There is a good calculator on 12 volt planets web site.
Voltage Drop Calculator | 12 Volt Planet Cable Calculator
Use our Voltage Drop Calculator to select the correct Cable for your campervan, motorhome or boat wiring application. Cable Calculator for Auto and Marine Electrical Components from 12 Volt Planet - Cable Size Calculatorwww.12voltplanet.co.uk
Same as i fitted to my 1500w inverter.I've recently fitted a 1500 W inverter and used 25 mm2 cable with a run length of 0.5 m and 150 amp fuse. If you're going to use a 200 amp fuse you should use cable that can carry that load without melting or catching fire so that would be at least 35 mm2 in my opinion. 12 V Planet sell this: https://www.12voltplanet.co.uk/extra-flexible-pvc-battery-welding-cable-35mm-240a-metre.html.
YOU may not, but if you sell your van on...?I will never run the inverter at max, my battery would not be able, I have decided on 60mm² cable and a short run so should be ok![]()
a minimal distance there, which is always a good ideaI haven't worked it out yet but as close as possible, I should think about 300mm
I haven’t done the numbers but I would think that would be fineI will never run the inverter at max, my battery would not be able, I have decided on 60mm² cable and a short run so should be ok![]()
If it does it’s most likely way under what he is going with, when I have seen something pre attached to a 2kw inverter they are usually like a shoe lace.Does the instructions for your inverter not define the size necessary? I know that Victron do.
I share other’s concerns regarding your plan and justification that you’ll never use full power. As an ex-gasman you should be familiar with accounting for inexperienced/foolish users and protecting them from themselves. Don’t be that person that‘s responsible for an accident ‘x’ years down the line when another user, not unreasonably, usescthe full capability of the inverter.
Do it right, you know it makes sense.
Ian
I
I got it on Amazona minimal distance there, which is always a good idea
For a 2000W inverter, I would go with 70mm2, but I wouldn't be overly concerned to see 50mm2 so your plan of 60mm2 will do the job fine.
(PS. I don't know if your 60mm2 come from a table that quotes the sizes in AWG and the 60mm2 was a metric conversion, but I am not aware 60mm2 is a buyable size. the sizes tend to go .... 16mm2 - 25mm2 - 35mm2 - 50mm2 - 70mm2 - 90mm2 - etc)
If we sell the van with what it's cost I'm taking the inverter outDoes the instructions for your inverter not define the size necessary? I know that Victron do.
I share other’s concerns regarding your plan and justification that you’ll never use full power. As an ex-gasman you should be familiar with accounting for inexperienced/foolish users and protecting them from themselves. Don’t be that person that‘s responsible for an accident ‘x’ years down the line when another user, not unreasonably, uses the full capability of the inverter.
Ian
Sounds like Lithium nextIf we sell the van with what it's cost I'm taking the inverter out
I only have a lead acid 95 amp hour battery, the inverter is to power a milk frother 480w so Mrs. Ex can have a cappuccino coffee off grid. We have a coffee machine but that is for EHU it draws 1470w and would kill my battery
Cables that came with my inverter didn't look up to the job, hence i purchased another set from 12v Planet.I
Then I would need a new charger and solar control. If it gets to that she can have instant coffeeSounds like Lithium next![]()
Maybe it would be sufficient but 0.2 of a volt could be enough to make the difference between the inverter cutting out on low volts and it running, in this case less is more in my book.I’m confused as to why you would use 70mm sq cable for a short cable run, running 200 amps maximum (because that’s what it will be fused at). The cable is rated at 485 amps according to 12 Volt Planet and their voltage drop calculator shows a drop of 0.9% for a 1 metre cable run.
35mm sq cable is rated at 240 amps and will result in a voltage drop of about 1.8%, or about 0.2 volts.
Would 35mm sq not be sufficient?
Because at 12v under load, battery will have a natural voltage sag by default, add a 1.8% loss on 12v is to big. You want as small as possible loss, under 1%, to avoid dc ripple. On 24 up to 2% and on 48v up to 3%. It’s all in the reputable inverters manual. The 12v planet calculator it’s just a indication for wiring, not necessarily accurate for sensitive equipment. A cable calculation takes many more factors in consideration, like method of installation, conduit/trunking or not, insulation rating, etc. Automotive wiring it has a very thin insulation, while welding or marine ratings are different.I’m confused as to why you would use 70mm sq cable for a short cable run, running 200 amps maximum (because that’s what it will be fused at). The cable is rated at 485 amps according to 12 Volt Planet and their voltage drop calculator shows a drop of 0.9% for a 1 metre cable run.
