- Oct 30, 2016
- 1,774
- 3,699
- Hymer BMC t780
- On 4th van so not a total newbie....
And if it’s coiled up, it stays really warm!
Tony
Our 25m is 2.5mm. As our 10m 1.5mm is starting to show it's age we'll probably replace soon.I’m the odd ball here.
I use 2.5 cable and it’s the stay flexible stuff in any weather conditions.
If on "free" leccy, in winter we will normally just leave the heating on 2kw, with a gas boost if needed, but turn off when using kettle etc. find this is normally sufficient as can is so well insulated.I use 1.5mm² for a 25m and a 15m extention.
15m is very short so 1.5 will be fine.
Contentals normally have 50m leads using 1.5.mm² it's fine providing you don't use electric heating.
You have got to be having a laugh... £71 for a hookup lead.....I'd want gold conductors for thatI have a set of these, 10m & 15m:
Absolutely excellent quality, good for a temperature range of +90 down to -40!![]()
16A 230v premium camper caravan hook up
Heavy duty 16A 230v 2.5mmsq premium orange rubber H07BQ-F cable caravan hook up CEE IEC 60309.toughleads.co.uk
Had them a couple of years, they were much less when I bought them.You have got to be having a laugh... £71 for a hookup lead.....I'd want gold conductors for that
We'll be using the existing connectors on the 10m length when we get home and these are the "extra" set we got to make up the 15m. They seem to be of decent quality.If on "free" leccy, in winter we will normally just leave the heating on 2kw, with a gas boost if needed, but turn off when using kettle etc. find this is normally sufficient as can is so well insulated.
We have a spare 25m cable so will go with Gellyneck suggestion.
That's what I'll do, as forgot we had a spare, but will do 10m & 15m as us more flexible, and we need 15m to connect at home.I have a 25M ehu cable and it is always too long. So I'm gonna cut it in half and add the necessary plugs to have 2 12,5M cables. Sorted.
Suggest, as we're doing 10m + 15m might give more flexibility than 2 x 12.5m.I have a 25M ehu cable and it is always too long. So I'm gonna cut it in half and add the necessary plugs to have 2 12,5M cables. Sorted.
Still got the original 25m cable which always seemed a bit long, hence buying a 10m & 15m.That's what I'll do, as forgot we had a spare, but will do 10m & 15m as us more flexible, and we need 15m to connect at home.
We hardly ever use EHU but when we do 25m is often too short especially in Spain & France.I have a 25M ehu cable and it is always too long. So I'm gonna cut it in half and add the necessary plugs to have 2 12,5M cables. Sorted.
I have heard that, hence the reason we carry all three leads and can connect them to each other if requiredWe hardly ever use EHU but when we do 25m is often too short especially in Spain & France.
Really? I've not been to France yet, but in Spain 25M was too long at every site we stayed at.We hardly ever use EHU but when we do 25m is often too short especially in Spain & France.
Unless you're on one of the UK club sites with a fussy warden who'll tell you that you aren't allowed joints...I have a 25M ehu cable and it is always too long. So I'm gonna cut it in half and add the necessary plugs to have 2 12,5M cables. Sorted.
Not restricted to "UK club sites".Unless you're on one of the UK club sites with a fussy warden who'll tell you that you aren't allowed joints...
And that applies equally to "wacky baccy" I am sure!!Unless you're on one of the UK club sites with a fussy warden who'll tell you that you aren't allowed joints...
