Cab usb Socket Upgrade? (3 Viewers)
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
Following our first trip in our 2018 Rapido 8096, we’ve come back with a list of ‘improvements’.
One of which is that the usb socket in the dash doesn’t charge the iPad, we use for navigation, fast enough. Having removed the panel and found the connections to the cigar lighter and usb socket, the wires going into the usb socket don’t appear man enough to swap out for something else.
Has anyone swapped their socket for something faster charging?
MisterB
6,363
14,510
Essex
Adria 670 SLT
Jan 19, 2014
9,522
25,144
Derbyshire
Elddis Accordo 105
since 2014
HKF
2,316
4,699
The Charente, France
Benimar Europe 740
Since August 2021
Just done the exact thing, will try to find the link but it looks like an aliens face in blue LEDs ....it was recommended on here and I bought it on Amazon.
Comes with bigger cables !!!
I'm looking into getting one of these, too, but then read this;
"However, a word of caution: Devices that charge with higher wattage also require special cables that can transport particularly high currents; otherwise, there is a risk of cable fire."
There's a link within that sentence that goes here;
USB 3.2 Gen 2 Type-C Device Cable
USB-C Male to USB-C Male, 1 m (3 ft.), SuperSpeed+ USB, 10 Gbps, 100 W / 5 A, 4K@60Hz, Black
SKU: 355223
Highlights
  • USB-C male to USB-C male
  • Connects a USB 3.2 Gen 2 Type-C device to a Gen 2 Type-C port
  • Supports speeds of up to 10 Gbps
Am I correct in thinking that it's necessary to buy new cables to use with this socket and ensure that only those new cables are used, please? Thank you.
MisterB
6,363
14,510
Essex
Adria 670 SLT
I'm not a techno, so hopefully others will offer the correct advice. Mine came with cables, which were a lot thicker, so I used those and NOT the original cables to the socket. I used thise connections to power the dash cam instead.
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
You need a QC3 one for fast charging. These aluminium ones are good quality..
Thanks very much for the replies, I've bought a socket from one of the MH accessory shops here, it's more about knowing that the cable to the existing socket is man enough.
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
SKU: 355223
Highlights
This is pretty much what I'm thinking about. I understand that inside the socket are the cogs, wheels and little aliens that decide what power is delivered to the item plugged into the socket. However with my limited experience the tiny cable going to the existing socket concerns me.
MisterB
6,363
14,510
Essex
Adria 670 SLT
I doubt it will be ... Make sure you fit a fuse relative to load and cable size
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
The existing cables are pretty much I've got to work with sadly, as they disappear into the loom. The cables to the lighter socket are thicker and whilst I could replace that, I'd prefer to keep it and have a decent usb socket too.
Jan 19, 2014
9,522
25,144
Derbyshire
Elddis Accordo 105
since 2014
You can use the supply to the other socket, wire in parallel 👍
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
Should be, unless it's a really thin one will be fine 👍
To me, it looks pretty thin and as far as I can tell it currently (sorry) has at least a 10 amp fuse.
edit, sorry it's the smaller red and black wires I'm looking at.
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
Which was my thought, thank you for the suggestion. Sadly it bugs me that I don't know whether it's ok to use the existing wires. In truth I hate not knowing these things, or being able to find a correct and reliable answer.
What if I went to my grave not knowing how to swap out a USB socket on a MH? :oops::happy::oops:
Jan 19, 2014
9,522
25,144
Derbyshire
Elddis Accordo 105
since 2014
Even if the small wires are OK you'll still have less voltage drop with the thicker ones. I would strip the cloth insulation back a bit, skin 5mm of each cable without cutting it and solder on to it.. Then tape it up. I did exactly this for the heated grips on the motorcycle.
Jan 2, 2024
672
889
Lincolnshire, UK
Peugeot boxer
Connect it in place of the existing usb try it if it blows the original fuse existing wire is too thin if fuse stays intact then all is good ...the fuse is there primarily to protect the wire as these sockets usually have very wide working voltage a small voltage drop won't be a problem
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
View attachment 917555View attachment 917556
Thanks both, I'll try using the existing wires and if it blows the fuse then I'll spur off the lighter socket.
Thanks again
Jun 12, 2020
487
1,443
Scotland
Carthago 138 Compact
Since 2017
How about plugging in one of these instead of rewiring. Charges my phone, Surface Pro and keeps the garmin going too.
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
Thanks, that's the sort of thing we resorted to on the 'inaugural voyage' but long term I'd prefer the usb socket to work well and leave the ciggy charging socket for whatever else. Papa Fiat meant it to be like that after all..... :coolest:
L
Jul 16, 2017
28
50
Gers, France
Rapido 8096
I'm a newbie
Just run a new cable back to the leisure battery, that’s what I did, they can be used when parked up as well.
That was my last resort and I might, ultimately do that as I'm planning on putting in more charging points in the living/bed areas. My thought was that once stopped and the front seats turned, we're not likely to use the sockets in the dash. But who am I, nowt but a novice.... 👼
Apr 27, 2016
7,071
8,304
Manchester
A class Hymer
Since the 80s
You need to know exactly what the spec of the USB socket is. The watts and amps vary enormously. The one in Richard n Ann's link takes 18W (=1.5A). The one in Russell's Dad's link takes 130W (= 11A). No point in getting stressed if it's only a couple of amps.
USB sockets use the data wires to work out what the socket can supply and what the device demands. A dumb device just gets 5V at up to 2.4A. That's about 12 watts, ie 1 amp from the 12V supply. Some high power sockets can supply 9V, 12V or 20V, at 2A, 3A or even up to 5A. That's up to 100W, ie about 8A from the 12V supply. These will be labelled 'PD' (= Power Delivery), and are capable of charging big laptops like a Macbook Pro. Some are double sockets, so you need to account for that. Most sockets are somewhere between the two extremes, you have to read the small print and do the calculation to see if they are suitable.
TheBig1
17,777
44,166
The existing wiring will be fine, but please don't go budget on the USB outlet. The cheap plastic Chinese ones have a very nasty habit of overheating and melting or catching fire
May 8, 2021
1,649
3,158
Bedford, UK
Bailey Autograph792F
Since June 2021
Exactly what i have and we charge iphones, ipads and even my macbook as we drive. Been using it over a year and never had a problem.
