Cab battery (stop start)
Newent, UK
Etrusco T6900
changing a load of things again
i have tried searching but just get leisure batteries. I think my cab/starter battery is on its way. the original is a Mopar 95ah EFB.
So has any recommendations for a replacement please?
when i type in my reg on Halfords i get "invalid vehicle"
2021 2.3 9 speed auto Fiat Ducato.
thanks
thanks
Do you have a good local independent battery supplier?
If so I’d go there, usually very good service, good prices and normally fit for free 👍
edit I’m not a fan of Halfrauds 😊
That is an Enhanced Flooded Battery, there are several brands and Halfords sell them too. Yuasa and Varta EFB for example. On the label, as well as the Capacity (95Ah) there should be an Starting Amps value, maybe called CCA Amps (= Cold Cranking Amps). That's the important spec for a starter battery, so make sure the new one has a CCA equal or more than the old one.
thanks
Have you tried searching for van base, forget reg? Big battery sites can search that way.
