Buzzing noise
Lobelia77
Bailey Approach 520
I have an intermittent buzzing coming from the vans EDU when on hook-up. Does anyone have any idea as to what may be causing it.
A loose connection is a possibility, but there are other possible explanations.
Does it do it when drawing more power? If so, and you are uncertain, get it checked out. Loose connections mean arcing, and arcing means heat. 😞
MCB’s can buzz when older or with high current draw. Check and replace
swimbo’s personal toys 🤣
Could be the transformer in the charger, give it a nudge maybe.
