Bubbling sounds from Alde heating (1 Viewer)
Nov 10, 2012
900
8,542
Lincolnshire, UK
Just looking
Over the last week I've noticed that the heating system is making very loud bubbling noises . The pump doesn't have to be working for the sound to happen it makes the bubbling noise for a good length of time.
Could it be air in the system ?
Advice appreciated.
Nov 25, 2013
1,109
1,738
kent
Swift Kontiki 669
Since April 2013
Is the noise coming from the expansion bottle/tank ? They do bubble.
WESTY66
5,688
13,831
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
Only noise I hear from my alde (other than the annoying start up cos it’s under my bed) is the expansion and contraction cracking of the metal fins and it’s not that bad tbh, don’t hear any bubbling. Only thing I can think of is there’s air in the system.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Sound like air in it then if it's coming from the seating area there will be radiators behind the seats.
Martin
Kevinthecat
Nov 10, 2012
900
8,542
Lincolnshire, UK
Just looking
It appears if I turn down the temperature the bubbling stops. Turn the heating up bubbling starts until temp is reached.
I will see if I can get an alde mobile engineer out.
Korgrocker
121
65
Dunfermline
Elddis Encore 285 - 2018
Since 2013
Is the fluid in the system ok? I had a problem a couple of years ago that seemed like a surging and bubbling noise when the gas was fired up, but a fluid change fixed it.
Paul an Jane MK
435
486
Milton Keynes
Elddis Encore 255
enjoyed the freedom over the last couple of years but still Wish we could have got away more often
Much like a household radiator system it ha bleed points. Mine has two and they are behind the seats and hidden behind a wooden panel.
Mine made a lot of noise when we first got it and I had to bleed and fill it with Glycol mix, not bad for a brand new van.
You just need to find out where your bleed points are, my dealer advised me, what Moho have you got?
Got to be worth a try.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
So it’s just when the pump is running which you would expect, I’m in the bleed the system camp, then you might need to top up the header tank.
Martin
Kevinthecat
Nov 10, 2012
900
8,542
Lincolnshire, UK
Just looking
Swift bolero here.
Was it hard to find them behind the panel?
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Swift bolero here.
Should be on a rubber bend at the high end of the radiator also should be easily accessible, should be(y)
Martin
Apr 10, 2010
548
538
Bedfordshire
Carthago
Since Sept 2003
If your van is more than a few years old, the fluid might need replacing, and if it needs topping up there might be a leak. I understand the new fluid is better and lasts longer than the old stuff.
There is an Alde depot in Wellingborough (see https://www.alde.co.uk/contactus.php); they're very helpful so it could be worth your while to visit.
cornish boy
892
2,365
Body in Hampshire, heart in Cornwall
Swift Kon Tiki 669.
not so newbie anymore - since 2016
Also worth checking the pump setting, it is not unusual for the installer to leave the pump set on high (number 5, I think from memory) after bleeding the system. (y)
ctc
Oct 12, 2015
1,502
2,506
Crowle
Hymer b680
New
Mine made bubbling noises until I turned the pump down to the recommended setting.
