- Oct 8, 2014
- 1,568
- 4,622
- Compactline 143
- I'm a newbie and always will be. You never know it all.
I have just cancelled my BT contract in favour of a payg wifi system. I have done quite a lot of speed testing with the 2 Huawei routers that I have and get really good up load and download speeds in my area. The latency however does lag behind the BT broadband but for my use this shouldn't be a problem.
My thoughts are to disable the DHCP server on the BT hub and then assign the Huawei to the same domain as the DHCP server.
However the way I understand it the whole home disc (mesh range extender) will not work directly with the Huawei unless being wired directly to the Huawei which I don't want.
So if the BT home hub 2 is in slave mode but is connected to the home disk will the Huawei be able to assign ip addresses through the wifi disk.
I am an amateur so any advice on the above set up or a better way of achieving a good signal everywhere utilising the above equipment would be much appreciated.
Les
Les
