ok folks might be a stupid question but if you are connected to someone's BTWifie-with FON can they se you are connected and do you get full speed
or are you restricted
bill
bill
bill
its the BT HOT SPOT les were just staying at home lost another tooth today just dropped outMight need password to get onto it, if they have set their security access codes up correctly you would need to know it.
Les
PS: where have you decided to go in the van over Xmas? as I know Normandy is off due to your hospital appontment. Good luck hope all goes well, the cameras are a lot smaller thesedays thank God!
Les
At the moment am probably closer than they are I am next door and there rooter in on the other side of the wall trying out my new BT connection through hot spot will go on my own in a bitTheir network has priority so if they are streaming your speed will be quite slow.
Also your speed will be quite slow as you will be some distance from the router you are connecting to. Wireless connection speeds drop off fast as the distance increases.
Thing is if connected can they see you are connected to ther hub it will be handy when away from homeTheir network has priority so if they are streaming your speed will be quite slow.
bill
thanks bud never know who's connection I will be on when away it will manly be for brushing and surfing the net bit of you tub for jay but I don't do internet bankingGenerally no, the owner of the hotspot cannot see who is connected nor can they see what you are viewing. HOWEVER!!!!
This because most hotspots are operated by owners who do not understand the tech involved. It IS possible to snoop on the connection and it IS possible to see what the user is viewing (with some restrictions).
My advice;
Assume that any hotspot is operated by someone suspect. Use a VPN if using a hotspot you don't trust OR do nothing that requires a password or passes information you do not want in someone elses hands. If this is not possible use your phone or MiFi to access the internet. This is not perfectly secure but for most intents and purposes absolutely safe.
I never use WiFi for banking unless it is a trusted hotspot.
On the speed front, I can't answer with absolute conviction but I do believe that your data rate is restricted to prevent you impacting the owners connection. I would presume there is some variability so that if the owner is not using it you get a faster connection. By this I mean the hotspots owners data will get priority and if they are using heavily your use would be impacted.
These are just my opinions.
unlimitedWhen I lost my 'phone line one evening I logged on to my neighbour's Hot Spot, it's known as FON isn't it?
Contacted BT on chat and reported the fault. Engineer nearby the next morning so fixed my fault as he was around!
If you are not on unlimited Broadband your use on a Hot spot comes off your allowance !
Put it under your pillow tonight Bill, I dont believe in Santa, but the tooth fairy never lets me downits the BT HOT SPOT les were just staying at home lost another tooth today just dropped out
but got full head of hare no teeth lol
bill
Let us know and we will met up if you pass this wayPut it under your pillow tonight Bill, I dont believe in Santa, but the tooth fairy never lets me down
Les
PS have a great Xmas, we might be up in Ayrshire if all goes OK.
It does if you haven't got an unlimited broadband account. BT say Fon doesn't get logged on your account but it does they have no way of separating the data. A friend found out when he kept getting bills for going over his allowances. I did a few tests and confirmed any connection to his Fon was being recorded on his data usage.It doesn't cost you, the customer, anything
I am OK unlimitedIt does if you haven't got an unlimited broadband account. BT say Fon doesn't get logged on your account but it does they have no way of separating the data. A friend found out when he kept getting bills for going over his allowances. I did a few tests and confirmed any connection to his Fon was being recorded on his data usage.
He had a hell of a fight with BT to get his money back.
As you have no option but to accept BTs terms on wifi with fon they can't charge you for going over, and you cannot opt out of the service.It does if you haven't got an unlimited broadband account. BT say Fon doesn't get logged on your account but it does they have no way of separating the data. A friend found out when he kept getting bills for going over his allowances. I did a few tests and confirmed any connection to his Fon was being recorded on his data usage.
