Broken tow thread
South East London
don't own one yet
since 2011
At lunch time we got stuck in a field and had to be towed out. We fixed a tow eye to the tow screw, attached a rope and a 4x4 tried to pull us out. After moving a small amount the screw thread snapped. I'm surprised that it didn't do the job I thought it was intended to. The centre where it has snapped looks like there maybe rust inside. I don't know what the implications are and whether it's fixable?
I suspect it has been used before and slightly bent.
Straightened was then "cracked" whilst it was being done.
Lucky it did no damage when it broke.
Yes. Looks like it’s possibly had a fault for a good while. Have you used it previously?
The towing eyes must be screwed all the way in , and even then they are only suitable for a direct in line pull if you try and pull at an angle they will often snap ! Sucoz in the pic that looks like an extension piece , as the female end is usually part of the chassis rail , and the part you screw in is just an eye and threaded male end . If it is an extension piece due to the vehicle being modified by the converters , the extra leverage is probably why it snapped .
No we haven't used it previously, we've only had it 5 months but the van is 10 years old, so may well have been used before.
Can they be repaired anyone know?
And MikeD there was a bit of damage to the bumper but nothing serious that I'm aware of.
Just drill it out, put a thread tap in to clean threads and put a high tensile threaded bar in.
Pop over to mainland or stop off on way home and I can get it done.
You could get one new from converters I would think, it would not be a good idea to try and repair the old extension .
I have sent the photo's to someone recommended on here to see what he thinks can be done. Thanks for your comments. Will let you know the outcome.
