Broken side mirror
Bishop's Stortford
Autotrail Delaware
Since 2011
This is the second of my woes for the week. Whilst travelling though Lancashire to Mossley I had an impromptu coming together with van with a metal mirror. He won. I now need to replace parts of my off-side mirror. I checked a Brownhills and the whole mirror replacement cost is around £350 (after 10% discount)! My Autotrail Frontier Delaware only needs the back of the mirror and the indicator light which are both sold on Amazon UK.
My problem is knowing which part to order. The mirror comes in small, medium and long arm but the integrated side light seems to be the same for all sizes. I measured the arm length between the cab and the mirror and it is around 17cm. The problem is the different sources give different dimensions for the medium and long arm mirror. One states the long arm is 17cm but another says 19cm.
If its a normal coachbuilt (2.3m) then long arm. You can definitely get non OEM ones cheaper
https://www.google.com/aclk?sa=l&ai=DChcSEwjnj7Wfk9_2AhUY7u0KHYCZB94YABAPGgJkZw&sig=AOD64_3mLE9Xwhit_wgmC5XAnZ-Fa7yiPw&ctype=5&q=&ved=2ahUKEwjQha2fk9_2AhUIi1wKHa9ZBzAQ9aACegQIARBP&adurl=
I fitted a nn OEM one which fits perfectly but check if you have the radio aerial inside as then you are looking a higher cost although it is possible to salvage the part and fit it yourself to the replacement.
