Broken 3 way fridge
1996 ducato swift mw
Hi there, i have a 1996 ducato swift. Ive only just bought it. Today i have noticed the 3 way fridge is not working on 12v 230v and it tics and puffs on gas but no sustained flame in the view port. Its an Electrolux RM4201.
Any clues tip or tricks to get going on diag? Ive tried most of the basic things. It is hooked up to 240v and it is level too.
Or any advise on what could fill its spot for a reasonable price
Cheers, Rich
First re the gas I would remove the side vent and then remove the gas feed to the bottom of the flew. Then remove the gas igniter and clean also there should be a brass jet within the body this will also need cleaning.here’s an example of what you’re looking for.
Re 12v supply, it may well be a relay within the engine compartment. Probably situated with 2 or 3 other relays ( split charger etc) here’s another image of what you’re looking to find
A few basic checks with results posted here may generate more helpful responses.
Three way fridge - are you trying on each selection manually or have you tried 3-way auto?
Gas - Do you have enough gas pressure to run one or, preferably than more than one, burner(s) continuously? You need propane (red cylinder), not Butane (blue cylinder) at this time of year.
240 volt - Is all the other 240 volts equipment working? Sockets? Battery Charger? Do you know where to look for 240 volts on the back of the fridge?
12 volt. It will likely be set to only run on 12 volts while you are driving - which makes it difficult to check for the voltage on the back of the fridge. Also, many 3 way fridges take ages (and ages more, and still more) to get cold on 12 volts. They like to be already cold wwhen you drive off.
