If you have code reader, you may have fault for A/B correlation?
Start with easy stuff by trying fuse. Try to manually lift upwards brake pedal. Brake switch is above brake pedal and twist 45/90° to come out.
Also check any plugs along chassis legs as often the original loom is extended and these plugs are open to elements. I've had 2 motorhomes now with this issue, both resulted in no brakelights. I had to bypass the plug with new cable
